Another opinion to add to the confusion
Hey Will, do not get hung up on the size / capacity rating! 3.9, 4.5, 5.2 cu ft..... while yes there is some truth to it, those are all marketing tools to lure buyers in, "Oh, the 4.5 is MUCH bigger/better than the 4.0!" That is B.S. and I seriously doubt you ever will notice the difference in every day use.
PLUS, if you don't already have the matching "monster size dryer" for that 5.2 cu ft washer, you will be overloading it with those uber-size loads, taking longer to dry.
About 4 years ago I bought a Kenmore Elite He5T front load washer. While shopping there were two washers side by side which looked exactly the same on the outside, however one was rated as 4.0 cu ft and the other 4.4 cu ft. I open the door and inside the looked nearly identical too. I went as far as taking a tape and measuring the interior dimensions and guess what? They were <span style="text-decoration: underline;">exactly</span> the same! The only difference in the "capacity" was due to the baffles, or paddles inside that make the clothes tumble. The baffles on the "larger" 4.4 cu ft machine where smaller (shorter) than the "smaller" 4.0 cu ft machine and that was the ONLY difference.
Any of the machines you listed (with links) use the same concept as the crappy Oasis, a wash plate on the bottom that "rubs the clothes" clean. Personally I don't like that type of washer because I'm not convinced they do that great of a job without causing premature ware on your clothes, IMHO.
I agree with others who suggest a regular top load / agitator washer. AND... I love the idea of cashing in the gift card so you can buy something elsewhere!
Personally I would stay away from any GE TL washer, solely based on their washers from the late 90's being total POS.
If there is any way to cash in that card and buy a Speed Queen, I say do it! Yes the "capacity" is less than those uber capacity TL wash-plate machines, but here are my reasons:
1. Speed Queens are built like a proverbial tank.
2. The cycle time is much faster, approx. 35 minutes start to finish, versus 1 hour+ for the "wash plate" machines.
3. It will clean better (like your dad's 90's Maytag) than any "wash plate" machine, WHILE being gentler on your clothes (IMHO).
4. As others have mentioned, the controls on a Speed Queen are simple, easy to understand and easy to operate.
So find a way to cash out that gift card and go buy the Speed Queen, you will NOT regret it!
I hope all this helps!
Kevin
