revvinkevin
As some of you may remember I brought home my first belt drive machine, this one, right at a month ago. I REALLY like it because it makes all the proper "belt drive" noises that I think it should. The only problem is the top had VERY bad cancer (rust)!
While I did do a few loads of laundry in it, every time I did, I would find some pieces of rust had fallen into the tub.... and one time even stained the white sheets I washed! Fortunately I discovered the rust stain before they went into the dryer so I was able to "soak the stain out" in another machine. Problem solved.
Also, I found I was not proud of the washer like I wanted to be... I was ashamed of the rust. But now I have a reason to be proud!
The photos before....
