westytoploader
- Joined
- Sep 4, 2004
- Messages
- 4,485
Very cool!! And for the ultimate in retro, use an MS-DOS-based computer with QBASIC or GWBASIC!! Vintage PC running a vintage washer! I'm assuming that since you're using Visual BASIC, the computer you picked up was a Windows-based PC. And you could also create some "command" programs that the machine would accept as you entered them in. I saw this in Waco (GT Field Trip to Texas Tech) in 8th grade, where they had vintage IBM PS/2s connected to robotic arms...I'm sure it was nothing more than a BASIC program with a programmed user-friendly interface. For example, you typed in "X" and the arm moved left, "Z", it moved right, and so on. Now, you could create a user interface, type in "S", and then the machine would pulsate for 10 seconds, energize the spin solenoid and spin for another 30 seconds, coast for a short time and then engage the brake. Would be a great demonstration!
Will the timer be a standard Frigidaire "snappy" timer for that particular machine or are you going to have an on-board display connected to the control board?
