Thanks for posting Robert
Thats impressive for self service machine.
Looking at diagram and reading above..it’s makes more sense to me.
However that trap (86) is something that needs daily cleaning by someone who would have known how to service it. Those clog up quickly and can cause the pump to suck dry and burn up if not caught in time.
The machines I worked with..well I knew the sound of a clog or a pump sucking dry.
Cleaning that trap was usually done daily at the end of each day to ready the machine for next morning.
I once was cleaning a down comforter and a seam busted loose and that trap and pump let me know it real quick!
The trap had to be removed and blown out with an air gun and pump sometimes had to be primed with solvent.
Certain stains were or treated with a water based pre treater but stain removed and dried with the same air gun on the spotting board before going into machine.
The detergent..Staticol I believe was the name of it..was added at 1% and sizing at 1% to the total volume of solvent in working tank. So it also make sense as to why it says “increased detergent dose not increase the systems potential for spot removal”
Water soluble stains really needed to be dealt with prior.
Every garment already had a certain amount of moisture in it (relative humidity) even if it felt dry, and you’d want the least amount moisture possible entering the system.
I’m still curious about this coin op machine..who drained and changed filter? Who recharged solvent? Who kept that trap clean during operation?
