Inglis TO-41001 Commercial Belt Drive Rebuild -A few questions-
Congrats on finishing the plumbing fiasco, cast iron is a nightmare to deal with when it's old. Shoot us a picture of the bathroom when you're done, especially if the toilet is original to the house.
Plumbing and bathroom adventures
Don't worry guys, I'm not stopping until this machines one of my daily runners. Been lots of fun so far, and it won't be my last washer restoration, either :D
Bathroom floors almost done. I wish the toilet where original to the house, But it's still an older, unique powerhouse. MK III Eljer emblem from 1991. I'd pull it and take it with me if I moved lol.
The cast pipe replacement was pretty satisfying. Learned alot about my house to say the least. I'll have pics of the finished job and a few along the way soon!
Cheers everyone! Snows almost gone, washer cabinets ready to be pressure washed on my next days off. Lots of gearcase oil slung around in that bad boy.
Bearings done
Hello all!
With my bathroom and plumbing back up and running, and thousands saved taking the time to do the work myself, I'm back in full swing on the washer :D
Today I pressed in the new center post bearings and seals. I gave the inside of the post another quick run with a small cylinder hone, and applied a thin layer of grease before pressing in parts.
The order I used for install is as follows: I pressed in the top bearing first, then flipped the base plate and pressed in the top bearing oil seal, and then bottom bearing and it's oil seal. I then flipped the plate back right side up, and pressed in the two main seals.
It went well, with no damage to anything. I used a piece of 1-1/4" ABS pipe to press in the main seals. I chamfered the inside of the pipe so there was no pinched seal lips. Did the inner seal, then used outer seal to guide and press the final one in. For bearings and oil seals, I simply used a stack of large industrial sockets that fit just perfectly in the center post :D No WP FSP factory install or removal tools needed. Just large hydraulic shop press. I'm sure it could be done with a hammer and patience as well.
I plan to put a tiny bead of marine sealant at the top of the center post to make certain my repair sleeve is sealed, and the original steel center post cannot rust at the seal and damage it over time.
I'd also like to install the outer tub on the baseplate AND THEN install the assembly in the cabinet. Just makes the work of sealing it all up much easier. Am I screwing my future self over doing this?
Thanks for reading! Happy to see those bearings and seals in place! Cheers.
Tub mounting begins
Hey all! Some late night work continues!
The other day, I punched out and glued some cardboard discs to the tub supports on the baseplate. Machine originally had a similar material there, I assume to keep noises at bay.
I'm just about finished mounting and sealing the tub. That bathtub drain washer you see in the photo is to go on the center post under the tub to keep a good pool of 3M 5200 sealant in that critical location. Pics to follow tomorrow!
I made sure I didn't forget to install the one carriage bolt for the motor mount before installing the tub :D Every little rust spot has been carefully removed, and given a quick wipe with the sealant as well.
After a few days of curing, I'll drill the three additional holes as John suggested for extra tub mounting bolts to make sure no new cracks forum in the tub metal. It's not super aesthetic, But it will be a reliable tub that holds water, and won't be seen.
See you guys tomorrow with pics of progress. We might be washing in a few weeks!
Tub sealed and curing!
Hello all!
A few days ago, I got the tub sealed, With extra attention paid to the center post, drain, and air dome. Per my last post, I used a bathtub drain washer to make sure none of the 5200 sealant escaped as I sealed around the center post.
The sealing washer that keeps pressure on the air domes twist lock had disintegrated. After digging through my plumbing parts stash, I found that a stainless backing washer and seal for a single handle kitchen faucet fits the air dome perfectly, and keeps just the right amount of pressure to keep it firmly in place. It also had a little sealant put on it, but I made sure to seal it from the inside as well as possible to avoid water getting in the sealing surfaces and compromising the seal with rust. The 3M 5200 bonds to the enamel and steel of the tub extremely well. The drain seal had sealant applied before tub was mounted, and then had some spread around it as well.
All tub bolts had sealant applied before and after tightening them down, and I drilled and added 3 additional stainless tub bolts as John suggested to keep the tub rigid and mitigate any further cracks. I also sealed the seams, as slight rust stains where beginning to seep from them.
I put a thin coating around the top edge of the tub as well, as there was lots of pitting and loss of enamel there. The bottom of the tub had many tiny but deep rust spots and some areas of thinned enamel. 4 of them breached all the way through. All that rust was painstakingly removed, and sealant thoroughly worked into them.
What may seem like excess sealant around the center post and drain was entirely needed, as there was lots of exposed steel and deep pitting in those areas from rust. There cannot be any exposed metal, as you all know. Especially in a machine going into routine use. The sealant is very snotty and messy to work with, But I'm happy with the results. Pics below. Thanks for reading and following these repairs guys! I'm just wrapping up getting the top and cabinet cleaned up!
Preparing cabinet
Hello to those following!
The other day I began disassembly of the cabinet, control panel, and coin acceptor. I removed the inlet valves and water level diaphragm switch as well. I started sanding and removing any rust from the cabinet and coin acceptor box. I removed any dents and repaired a back corner of the cabinet that was a little bent up. The rear levelling system now works as it should. I then pressure washed everything thoroughly with a degreaser.
I applied a little paint on the bottom ridge inside to stop rust from forming again. I also applied a little porcelain touch up paint to a few marks in the top.
Today, I leak tested the tub after the sealant has cured for over a week. No leaks whatsoever after many hours!
Tomorrow I will paint cabinet and coin acceptor, as well as clean up all the control panel and coin parts and components. I also found a new agitator cap, since the original is slowly turning to plastic dust. The larger surgolator cap should fit and cover up some unsightly staining I was unable to remove on the top of the agitator as well.
I test fit the agitator on the new agitator shaft and its a little loose on the splines. The plastic splines in the agitator don't seem to be damaged and there are no cracks. I guess the rust swelling on the old shaft expanded the opening a little. Any tricks for tightening this up? I know once the stud and seals in place it will firm things up a bit, But I'd prefer the agitator be as firmly in place as possible, while still removable for future work if needed of course.
Enjoy some cool pics of commercial washer control parts. The Singer diaphragm switch looks pretty cool. I love stuff like this. Very serviceable control section thats nice to work on. Neat how the timer drops into the coin box. Wonder if any adjustments can be made for longer wash etc. I'll also be installing a lid switch bypass toggle switch somewhere accessible in the coin acceptor box as well.
Thanks for reading as always! Any comments or suggestions always appreciated!
Commercial belt drive washer restoration
Hi Landon, progress looks great. I don’t think anybody in our group has ever restored a commercial machine before that’s kind of fun. What are you gonna do with all the money you collect, lol
I don’t know any way to make that agitator tighter on the shaft Maybe if you slightly heated it and put it on the shaft?
In any event, we still have those agitators around if you just want to get another one sometime, it won’t ruin the shaft. If it wears out strips out it’s pretty tough stuff though.
I still know of a Kenmore just like this that’s still in regular commercial use in a small apartment building in Northwest Washington.D C.
John L
Thanks for sharing all these updates Landon. Its really great to see the progress and looks like you are putting an incredible amount of effort to do everything right. The finished product is going to last for decades I bet and looking forward to see this one come together.
As to the agitator shaft being a bit loose on the splines, can't really think of a way to rectify that really other than what John said already about warming it up a bit. I see in your pictures you have one of the plastic drive lugs to use an old style agitator as well so it gives you some more options if you ever happen to come across another agitator and it also happens to be that style.
Good luck and great job so far once again
Hey all!
Looks like the site changed and lost alot of it's "cozy, old school forum" feel. All good. Looks like everything has moved over just fine, and I'm glad it will remain online as a very valuable resource of information.
Significant progress has been made on this machine!
-Cabinets been re-painted, and a few chips in the porcelain top touched up.
-Tub and baseplate installed in cabinet.
-Coin slide assembly has been cleaned and painted.
-Transmission and basket drive have been assembled together and adjusted just right.
-Wiring, fill switch, inlet valves, and control parts have been cleaned up.
-Transmission, motor, new belt and braces installed and wired up!
-Pulley swapped on pump, and pump installed.
I made sure to fill each bearing in center and spin tube with oil, and made sure machine was upright before tightening bolts holding transmission in place. I also gave the NOS Whirlpool pump a little oil in its wick. at over 20 years old, I want it to have a good start.
The one brace behind the motor was a little short to reach the transmission, and needed a little squeeze in the vise to get it just right, but other than that it was alot of fun and everything went together nicely.
To get the assembled tub and baseplate assembly in the cabinet, I found it easiest to lift the cabinet with a small chain hoist and carefully lower it down over the assembly.
All thats left to do is-
-Re-assemble the control panel, and coin assembly to the top and wire up the controls.
-Install drive block-- Do I really need to bend the metal "tabs" on the spin tube to hold that in place? or does it pinch on strongly enough with inner tub and nut? Couldn't quite tell if original had tabs bent, or if it was just corroded/swollen
-Sand off rust and re-paint snubber plate (porcelain coating worn through. May just make another out of stainless or galv. metal)
-Install tub cover and snubber
-Install agitator and assemble top to machine.
See pics! many more to come! and thanks for reading. If there is anything I'd like to get for this machine, It's a new tub cover. This one has plastic getting dry, crumbly and grey on inner edge, and as I said, the snubber plate is pooched. And perhaps a new agitator as this ones a tiny bit discoloured and loose on the shaft. I wouldn't mind a tub cover with that pull-out lint filter if it's all that's available in the future. For now, I'll make what I have work just fine. Thanks John, and James for the kind words regarding the progress!
Bonus pic of a 1968 RCA-Whirlpool air conditioner I've been working on restoring alongside this washer :D Hopefully the washer works as well as it does when I'm done with it!
Good morning Landon, it’s really coming together. Looks like it should be running well for a long time to come.
I’ll save a plastic tub cover and agitator for you, you can also replace that little metal snubber plate. I’m sure we have lots of those laying around
That whirlpool air conditioner sure is in great shape. I don’t think whirlpool made that air conditioner. I believe they were made by a Canadian company for a number of different brands, the same company also made a long thin one that went through a casement window. There are a lot of of those in the US
The air conditioners that whirlpool built throughout the 60s and into the 70s were fantastic air conditioners extremely well engineered basically almost never rust. The coatings were so good on the chassis, etc..
There’s been a few posts about these old whirlpool air conditioners, I did a post about a Sears version from 72 that still had the auto dehumidifier system where it had a second condenser behind the evaporator so it could actually Cool and dry the air and re-warm it so you could continue to dehumidify until the humidity gets down to the humidity level.
The machine is completed! :D
The final reassembly and finishing touches went very well, and I’m very happy with the result. The machine has done well over a dozen loads with no issues, rattles or leaks! It runs very smoothly and stays in balance. It's so nice to have a belt drive unit like this to use again! So many sounds I haven't heard in a very long time. I really enjoy using it! I made sure the clutch/brake assembly and yoke are all properly engaging without anything rubbing or slipping in all modes.
I easily removed the cams in the coin slide, and put them in a safe place. The machine will start a cycle by pushing the slide in as usual without using any coins. Under the coin mechs access door, I installed a "lid switch bypass" switch, since the internal mercury switch is hard to access when you want to watch the machine spin. I also adjusted fill to be a little higher.
The inside of the cabinet appeared to have marks where small pieces of noise dampening foam was once installed. I used one 10"X12" piece of Killmat on each side and front, and it totally eliminated some drone/resonation from the cabinet, allowing you to hear the mechanism and wash much better over the hum of the units split phase motor resonating through the cabinet. You can hear a faint "woo woo" type sound during agitation that I remember fondly.
All in all, the unit works like new, and current draw remains under spec as it should be. The unit was sadly missing one clip for the tub cover, and only has three holding it on for now, and badly needs a new snubber plate, as this one is heavily pitted, and paint does not last on it (as I expected), causing it to rust between uses and sound scratchy, and likely not snub correctly.. I'd really like to rectify this. I am relieved that the agitator is tight and firm now that its bolted in place. I was concerned its splines where a little worn, but its perfect once it was secured in place. Pics below, and videos will follow in a couple days! Thanks so much to everyone following, and to John (Combo52) for supplying the parts to make it possible.
John- The Air conditioner in my last post was certainly manufactured by KeepRite for Whirlpool. They made most, if not all ACs for the Canadian market under brands like Whirlpool, Admiral, and Electrohome. They made fantastic machines, and used reciprocating Tecumseh compressors in most of them until the late 1980's. They where built a little different that true WP made units, but still simple, good quality and a decent coating of paint on the base pan. All are usually quite underrated on BTUs, and perform well. The fans in the units some may consider a little loud. All the Admiral/Whirlpool branded KeepRite units still have "FSP" on all the components. Even one Electrohome branded unit I own has FSP on the key switch mechanism, but that could have been swapped in the past. I still use these air conditioners exclusively in my house. The Whirlpool casement unit I posted has been keeping the whole upper level comfortable without issue all summer now! :D Cheers.
Stay tuned for videos soon!
Landon - congratulations on finishing off your project. You did an incredible job and your attention to detail is top notch. The machine looks mint both inside and out and it will most definitely last you years to come. Thanks for sharing all your updates on your progress and explanations along the way - they will be a great help to others down the road.
Once again, great job and enjoy your new machine!
Fantastic job Landon, yes, indeed it looks like a brand new machine, these were fairly rugged machines. I know where they’re still a pair of these working without having been rebuilt in a small three unit apartment building.
The lid was hinged back instead of sideways because in a commercial setting, the sideways lids would not be very durable. The hinges would get broken with people, shoving baskets of laundry around I suspect. Kenmore top load washers always had more trouble with lid, hinges, etc., than whirlpool because of the sideways arrangement.
Hi Landon, I’m sure I have snubber plates around. I’ll have to send you one at some point
Last week we pulled out three commercial machines that were used in small apartment buildings where they had about six apartments. We pulled out one of the first direct drive whirlpool commercial machines it was still working fine, but it was very tired and because of the very high water cost here the owner decided to put in a Speed Queen front load washer, the Speed Queen electric dryer was from 86 I guess about the same age as the whirlpool belt drive machine. It had a motor that was failing so I replaced it with a used whirlpool electric dryer
And the Speed Queen top load pictured went in a 1978 and it was still trucking along. I had to put a new timer in a year ago but the water pump finally seized up and the owner just said get me another washer I put any used top load Speed Queen that’s about 20 years old. Non-coin up, in both buildings they decided just to make the machines free and ask tenants to add a few dollars to their rent for each load of wash. They’ve washed and dried, this often works very well in small buildings.
John L
    1.6 MB
    1.3 MB
    1.8 MB
    1.4 MB
    1.6 MB
    1.9 MB
    1.7 MB
    2 MB
    1.6 MB
John L
John, I certainly understand why they used a back opening lid in a commercial machine, but why the Kenmore lid rather than the standard Whirlpool lid, which is normally used?
Tom, another reason might be that these were built by Inglis vs Whirlpool. Inglis was still a separate company at the time these were built and as such were manufactured in their own plant - they just licensed the designs from Whirlpool. Usually Inglis built machines (including Canadian Kenmore as well) had different cosmetics, used older parts, had different features etc
Hello everyone, and thank you for the kind words on my efforts! It's completed another 15-20 loads without issue. The transmissions fiber gasket is still a little moist with a little oil seepage, But I think thats due to me overfilling the transmission a good bit. No drips, so not concerned.
John- Those are some really neat commercial machines! They seem to have held up really well. The DD machines tub ring looks like it has had some UV exposure and turned to shatterplastic. Since you said its one of the early DD machines, does it have the earlier non-neutral drain gearcase? Too bad I'm not closer I would have loved to buy these machines they would be another project I would enjoy.
If you come across a snubber plate (I have several of the pads) and a couple tub clips please let me know. I'd be glad to buy them off you.
The lid is definitely a side-opening Kenmore style lid with back-opening hinge holes drilled, BUT Some domestic Inglis Niagra BD washers also used the lid in the same configuration as my commercial unit. You can see from my picture below, that the lid has the provisions for the lid switch plunger for the sideways hinge configuration as well. My machines lid also has a spring on one of the hinge pins to make it noticeably easier to lift.
