volsboy1
I think all this Vitriol about heat pumps is from past experience with these Old American Type we have all grew up with.
For the longest Heat pumps being one speed were sized for cooling.With Heating deficiencies were made up with Heat Strips.
Variable speed compressors have been available is Asia for quite a long time compared to here.
Having a variable speed compressor greatly enhances its cooling and heating moxi of any system.Even now there only in high end systems . The Mini Splits of Asia have variable speed compressors all across the board with there lines for the most part and they also use .
Flash Injection and multiply expansion tricks and Sub-cooling helps greatly. After its giving up its heat to the indoors its heading outside but there is still heat inside of the refrigerant left over. A sub-cooler lets a portion of the refrigerant flash expand and cool and remove that heat and send it back to the compressor for re-compression.This allows the refrigerant to absorb much more heat from the cold outdoor air.
When I got my Rheem unit last April I was told that Mini Splits can't be tied into existing Air-handlers and coils upstairs.That is a Lie. These Air contractors hate these diy folks and will say or do anything to keep you paying 15 grand for a new Top of the Line Trane/Lennox unit.
I can't afford Trane would not want it so I got a plain single stage Rheem. I could have got a Variable speed 3 ton mini split and tied into my Air-handler and had a system that could cope with temps down to below zero and for much less money. My Rheem once it hits 20 it never turns off and the best it can do is 68 degrees anymore and the EM heat kicks on.
I am thinking about selling my Heat pump and doing it anyway I would break even but I would have a better 20+ seer system instead of the 15 I have now.
