This knocking/popping/whatever-you-call-it sound this washer is making is about to have me needing heavy medication. I've been patient and tried to ignore it and stop worrying about any little weird noises because of the machine being so different than anything else, but I know without a doubt that THIS noise wasn't intended with the design.
For anyone who didn't see my post on the original subject of this washer, it's a Maytag Bravos XL MVWB725. It performs beautifully, and I've grown to love how the machine works and have learned the do's and don't's in order for it to work properly. Since around January, it's been making a sound that I can only describe as though someone is tapping their knuckle on the plastic of the agitator, and yet it only makes the noise when the basket is rotating slowly, or in the first part of it ramping up to speed in the spin. There isn't a thing I can see that could be making the noise, because the outer tub can be completely still and it will knock away, and there isn't a thing that I can see underneath that is loose or moving. If you rotate the tub by hand ever so gently without causing the tub to rock, you can feel the pop. The best way I know to describe it is like your ankle popping, you can't see anything happen but you can hear and feel it.
I've taken some video, and this one was the most clear. I let it rotate slowly, then stepped it to medium speed, and then full speed. Notice that it does it a little until a certain point and then goes away completely. At the end when I stop it, and then start the slow rotation again is when it really starts making the noise, around 2:15.
I'm at a stalemate. It does it so intermittently and yet when it does it sounds like someone is knocking on the door. And I most certainly don't want to just ignore it only for it to turn into a major failure in the bearing.
<iframe width="560" height="315" src="" frameborder="0" allowfullscreen></iframe>
