dartman
Well my house has PEX pipes and one of them was leaking at the 90 in the wall that feeds the washer. Found it early when I was under the house in the crawl space looking for a bad cable wire. The whole floor has insulation inside a plastic liner with the pipes and heat ducts inside it so if there's a leak its hard to find till the insulation and plastic fills up with water.
Luckily they gave me a year of home repair insurance with closing so I used it rather then do it myself.
Cost 60 bucks copay and was fixed 2 days after I called.
Hadn't been leaking long so drywall and framing was all fine. Nice thing about pex is its easy to deal with, tends not to split open if it freezes, and like that. I even have heat tape already installed onto the main incoming water line with a outlet on the top of the crawl space by a vent that includes the main shutoff valve. I need to redo the shutoff someday as the rehaber did a lousy job cutting out the old one and putting in the new one, it barely seeps where he did a crooked cut and put the crimp too close to the cut.
Moms house is a 90 manufactured and some of the pipes in the wall are copper but underneath is pex as well and she just had the pipe feeding the second bathrooms toilet crack.
Lucky for her her house had the option to install shutoffs for all the pipes leading to fixtures. She didn't opt to have them added but the pipes still have drop downs designed to be easy to cut out and add the shutoffs, they also have threaded stoppers they took off and left under the house when they were told to just connect everything directly. I was able to unscrew the adapters and put the caps back on the pipes which shut off the water till she got a real plumber out to fix it.
Hers was leaking so bad you could hear the water running and all the plastic wrap and insulation was soaked. They ended up replacing all of it and hard to say how long it took for all the water to evaporate.
Hoping mine has extra shut offs because there are access panels that say electric and plumbing on them but not going to crawl under there and drop one till its warm and I feel like it.
