"I saw this thread about the percolators and wonder did they make better coffee than the coffeemakers we have now?"
This is probably a dangerous question to answer. First, this forum does tend to value older appliances. Secondly, I'm not sure I'm qualified, since I've not done enough comparisons.
This said, percolators are considered by coffee experts to be horrible. The process cycles brewed coffee through the system, subjecting it to higher heat than brewed coffee should get.
Then, some experts point to the percolator coffee smell that some get nostalgic about, and point that smell should be staying in the coffee when you drink it.
Another thought: aluminium was very common in old percolators. Many were all aluminium. Aluminium can, theoretically, react with the acids in the coffee, changing the taste. Then, there's the possible aluminium/Alzheimer's connection
My own experiences tend to show percolators are limited. I have an old Corningware stove top. (Stove top percolators, carefully controlled, are the only ones that I've ever seen tolerated by a coffee experts--and, to date, only one.) I've never had luck getting it to perform well, but, then, I haven't spent much time, either.
Another, an old Regal Poly Perk, makes coffee that's drinkable, but not as good as what I can make with other coffee makers.
Still, I wouldn't pass up an interesting percolator. And some might have done better than others.
The best bet for a good vintage coffee maker is a vacuum pot, like the Sunbeam Coffeemasters.
