Time to order your Westinghouse Door Boot!
sudslock1
Dec 22, 2010
147
St Louis
Guys I've spoken with a rubber extrusion company and I am making final arrangements now to have Westinghouse Laundromat door boot Q-4688 reproduced. Another member on here supplied me with a NIB boot from Westinghouse that I could use to have a new dye made. I need to know how many people would like to have one (or more) of these so I can start coming up with a solid number to have produced. The dye would belong to me so I could have more made down the road if I wanted but I think it would be wise to just make enough to last for a good long while. The gentleman at the rubber company gave me some ideas of different materials I could use but there is a cost factor so if there are only a few needed I'm not going to use anything super high grade and just try to go with OEM specs. Please let me know either by replying to this or sending me an email on here so I can get a number together. Thanks
Depending on the final $$$ numbers I would be definitely interested.  Unlike most solid-tub washer outer tub boots with a flat sealing surfaces, this boot will be a challenge to produce proper sealing, but I suspect it can be done.
Materials
It all basically comes down to how many I have made. If only a few people want one I'm not going to go all out because the cost would be outragious and I doubt anyone would pay it. If I can have about 50 or even 100 made then I can spread the cost out for them enough to go with a higher grade material that would last past the life of any current user or for that fact the machines themselves.
Interesting.
What machines will this boot fit? I don't have any Westinghouse washers and if I want to order one "just in case" I'd like to know what it might fit.
Is this for the Slant Front machines, the Flat Front machines, the Spacemates, etc.?
If this supplier does good work, perhaps more parts could be re-made in the future, like Frigidaire bellows, early Maytag HoH dryer door gaskets, etc.
Very interesting.
PS: If possible, please have the part number(s) as part of the dye so it is evident on the finished product.
Dave
Door boot Q-4688
Yes I'm with Dave (Volovoguy87) here, what do or will this fit??
I have a late 40's or early 50's (not exactly sure) Westinghouse slant front washer AND a '57 Spacemate washer.    Both need new boots.   Unfortunately the NOS boot installed on the Spacemate in April has already failed (come apart at all the seems) completely!
So depending on the final cost and which machine it fits, I would be interested in at least one, maybe two.
Kevin
Q-4688 boots will only fit Slant-Front/Slant-Tub Laundromats from 1949 on up.  They will not fit Slant Front/Straight Tub or Straight Front/Straight Tub machines (1964+).  Nor will they fit the Space-mates.  Still slant front Westinghouse Laundromats are not too rare so there should be plenty of machines where this boot is needed.
Before 1949 no boots were used as the washers had an outer and inner door.
Put me down for three!! Please contact me if you need any funds in advance. Thank you so much!!
Production will start..............
Guys. I am waiting on a final quote from the company and then I will place the order for an inital run of 100 boots to be made. I will give a couple options for material on here and color before I make the final decision to see where the cost will be and if everyone agrees. I was told that white most likely would NOT be possible as the company produces mostly black rubber parts any white parts made would most likely have black traces through out the product so an off white or grey would be more likely. Any thoughts? Also, when all is said and done I will see if it is worth remaking a spacemate boot if all goes well with this one.
Dave
I'm assuming the original was white, I don't think I've seen one (or don't remember seeing one).   What ever (reasonable) color you come up with is fine with me.   Off-white, light or medium grey... perfect!
Kevin
