Timer Help for my 69 GE
geextrarinse
Jun 2, 2004
533
Hudson Valley, New York
Ok guys - the day has arrived that I was dreading. The timer for my 69 GE seems to have bit the dust. First thing I noticed was that it would only wash with hot water, no matter what the temp setting was set at - it would not energize the cold solenoid. Now, it doesn't want to agitate but it spins. I was able to fill the machine and then it does nothing so I am spinning out the water and will have to just dry my clothes and wash them elsewhere. So my question is - can this timer be repaired or dose anyone have a timer to replace it with?
There are 3 or 4 leaf switches . One of them does control agitate and spin. I think they are removable without taking the whole timer apart. I think it's switch # 2 or 3. Also there should be a label glued to the back of the control panel that might help. Not sure about the hot only wash.
can we see a full pic of your control panel, and a pic of the timer?.....
I can look if I have a timer, or pieces we can switch over and replace....
if all else fails, I am wondering if we can do a complete control panel change-over....
also do you have the standard tub, or the largest capacity?
just some thoughts if we can help out here....
