Sorry I took so long to finish this up,but here goes.
The odd looking flat pieces of metal that tied the fine coil wire to the large power leads were going to be too difficult and risky to use again. They originally sat in slots in the black plastic block with a short piece of wire lead crammed into the hole below them, then they were sealed in place by melting the black plastic and spreading it over the top of the slot. You can see the way they were installed in reply 10 if you’re curious. That sort of thing seldom works more than once, and I was really worried about breaking the little wire leads. So I did this instead. It’s not pretty but it works, and with any luck, nobody will ever have a reason to be in there again. “Fingers crossed”
