David Westy trivia.
They were stacked a set shows up on POD ours were white, They were almost new and came with a home my parents purchased in 1958. I guess they were about a year old. This set had the dryer flipped upside down when it was stacked. You turned it right side up and flipped the chrome panels so the "words westinghouse and clothes dryer were right side up, you also flipped the timer knob so "off" would be Up. (if you planned to use it side by side). The Laundromat died out in the late 60's, and was replaced with a T/L maytag, the westy dryer was "turned right side up" and lasted until the late 70's, Todays POD, mentions it dries at 163 degrees, IIRC. I can tell you that glass window got Very Hot in ours. When the laundromat worked they were true mates capacity wise, after the dryer was paired with the maytag it seemed small. arthur
