Took everyone's sound proofing advice
blockeight88
Apr 11, 2021
643
Northwest, IN
New 2002 Kenmore Elite washer with matching dryer. This came with the "Quit Pak III" and had the bottom sound absorber pad on the base. Well I took it a step further and insulated the outer tub today. Huge difference that makes. I definitely got a little creative with it. Thanks for the motivation.
Reply 3
I did. But it did have those rectangular sound panels from the factory. I just got done doing my 1994 kenmore’s Direct drive. That machine didn’t have anything install from the factory to help with the noise.
Sound Deadening
Did this to my Duet dryer with some Amazon sound deadener and some sound absorbing material. It took it from sounding like a MOL product to sounding as solid and refined as a machine built in the 60s. Did the same treatment to the KUDS25. It was quite a bit quieter, though you can't do much to drown the motor sound out of a PC. Though, I enjoyed that noise any ways.
I lined the top panel on the Kenmore FL with the same sound absorbing material, though with less of an effect to the already quiet machine.
I didn't even think about the dryer. The matching dryer I am using has the "Ultra Quiet Pak" but probably could use some additional sound deadening material.
Made a HUGE difference with the washer.
I like it
It's a good idea.
I would just make sure not to create traps where moisture can get stuck and cause rust or mold.
Where the outside tub sets on the main frame I have put on the bottom of that outside panel, when I had such a top load Kenmore washer, roll foam weather stripping.  It acts as a cushion helping to prevent rattling and noise.
https://www.walmart.com/ip/High-Den...222227143690698_142029117597_18503877779&wl0=
Adding sound dampening to appliances
I would be very careful with clothes dryer’s not to put anything near the heater, gas burner or above them, etc. you don’t want to create a fire hazard.
Also on a dryer, be careful not to put something on that could come off and get wrapped up in the drum or motor, etc. which also could create a fire hazard.
John
Reply 10
I’ll probably just pass on the dryer. It’s not worth any potential fire hazard and neither one of mine. I really doubt loud to begin with so I’d rather just not mess with it.
In my experience, dryers are really only as loud as what you put inside them. Sure the motor makes some noise but what really matters in a dryer are things like zippers, hooks and buttons bouncing around in there. Simple actions like buttoning/zipping jeans can make a big difference.
