At my partners place, we used to have a (pretty old) AEG T59800.
It's pretty damn good as dryer - just old, noisy and not that efficient anymore.
It's still running, but I shuffled some money around and bought something new.
The T59800 is going to a friend of ours.
So, a few weeks ago, we had the cutting edge in dryers delivered.
Payed - including the cashback - a little under 1000€ shipped.
First, why this?
It's basically the first AAA dryer on the market.
For those not in the loop: Next March, a new energy label for dryers will be launched, similar to the current washer label.
Roughly, A+++ will be C, A+++ -10% will be B, and A+++ -25% will be A.
Condensation efficiency will require a 94% or better for A, and noise will be A at 60db and below.
It's A+++ -25%, its 60db and 94% condensation efficiency.
I didn't think it was THAT easy to build these - but it is apparently.
It has AEGs new base design.
AEG realised that with a heat pump dryer, you don't need to have the heat exchanger in the bottom left.
You used to with condensers, so everybody just reused their base designs - but if you phase out condensers, you no longer have to.
That allows better airflow with lower pressures, bigger heat exchangers which mean more surface area for heat exchange and thus more efficient heat pump operation.
All at the cost if having to move your process air fan - which results in this fan being belt driven.
Further, this has ELuxs contactless sensing.
Only clued in as to what they do when I read "capacitive" sensing in their product description.
Instead of sending a current through the load, it uses the same basic principles as the capacitive touch buttons on appliances to sense moisture.
Combined with the weight sensing these ProSense dryers do now, it really is pretty accurate at time estimation.
These TOL models are inverter heat pump.
And performance?
Pretty damn amazing.
I do recognize that odd "feels damp" at the end of some cycles as this dryer REALLY is airtight - but it really isn't bad and clothes feel dry once they cooled down.
It senses basically spot on on everything every time. I do find selecting extra dry is necessary on certain items - but since it doesn't really heat up much what so ever that's usually no worry.
And it really is that efficient.
A load if 58 T-Shirts (that's technically overloaded for this dryer, but it didn't complain) used only 1,2kWh on Cottons Eco Cupboard dry ++.
8kg (the W1 was packed) of towels used the same.
Only time it was TOTALLY off with its time estimate was a heavy bathrobe and a couple of towels taking about 90min less than it estimated.
There is one gripe and I am not certain how major it is.
The very first ProTex dryers had a slew of complaints that socks would get stuck in the corners around the filter due to the massive airflow. Then they redesigned the filter housing and that was solved.
This dryer has a tendency to catch bands from sweat pants or such in the bottom right corner between door, frame and filter.
Twisting them so far one band actually just ripped off.
Happend on 2 occasions so far, so just like with my VZug I'll have to tie up those bands.
I do also however think the inverter heat pump isn't as well designed on this one as some other manufacturers do.
It's a simple speed control - the power just fluctuates.
And most of the time, it stays at a single speed through out a cycle. Except on Time Saver, where a certain temp triggers a drop in speed.
It still just stops the heat pump on the MixDry and Bedding cycle for even drying - so now fluctuations in power there either.
Time Saver isn't that great at saving time on many cycles.
Except for the bedding cycle - where so far I rarely have seen much deviation in usage for pretty similar loads regardless of Eco or Time Saver.
The one item cycle just SLAMS the heat pump and appears to just run a timed cycle.
So that really is just used because the inverter heat pump is ever so slightly more efficient.
First, why this?
And performance?
