tractors
I don't have any, but enjoy looking at them.
One of my friends, however, is really into John Deere. He and his brother currently farm over 700 acres, and most of their equipment (including combine) is JD.
My sister's husband (farmer) has a Case-IH, JD, and Deutz-Allis. He doesn't have a combine though.
I missed that.....
Missed the Montgomery Ward badge on the riding lawnmower the first time through. Montgomery Ward must have been like a Sears. Wonder if MW had an automotive department like Sears did. Montgomery Ward came to the Greenville Mall here in South Carolina. I shopped there a few times, but I don't remember seeing appliances, lawnmowers, etc. Anyway....
after using the 1975 "ym1500d"tractor i bought a little,i noticed the main bearings in the engine were a little loose,so is currently apart for a repair-since the engine is apart,just about everything else has been checked/cleaned and repaired as needed(some rusty bearings were found in the front axle)a repaint will be done too-engine and chassis is a silvery green color that i haven;t beed able to find in a spray can so far,so may have to have a match mixed up and use an air sprayer.Unlike most gas 4-stroke vertical twins where the two pistons go up and down together,the diesel in the yanmar has the pistons moving in opposition-one cylinder firing right after the other then a pause as the engine rotates through to fire #1 cylinder again;sounds a lot like a 2cyl john deere but not as deep of sound.Engine is very overbuilt for 17hp at flywheel-built more like a stationary engine than an automotive type as found in newer small diesel tractors.Yanmar has also built a lot of "putt-putt"small marine diesels too.
Yanmar also built small diesel engines for those mobile electronic signs highway depts use to warn motorists with-the Yanmar motor runs a small generator in the base of the sign keeping batteries charged that make the sign work.Get close to one and you hear the Yanmar engine putt-putting away.The engine is very quiet-it runs at slow speeds.And the tiny Yanmar engines sips fuel-the sign can run for hours on end with just a couple gallons of fuel.
electric sign generator
lombardini is another brand of small diesel used in those moble signs-looked at one once and looked like there was a motorola automotive alternator belt driven from the lombardini.Besides the small "putt-putt"diesels for small boats,found out yanmar also makes much larger marine diesels as well.One diesel brand that has been out of buisiness for a while is Buda-these engines were found in a lot of applications from around 1935-1950 years including tractors,trucks/buses,and army generators and vehicles-a 1942 army generator i fixed once had a Buda engine
Buda Diesel engine-A man I knew that was in Viet Nam who serviced genrators for the military camps had one large Buda generator.The Viet Cong targeted the generators.He told me the poor Buda got a direct hit from a mortar shell and that was it.Buda engines were also common on construction equipment-the large air compressors used them a lot.Then Buda just disappeared.My friend from Viet Nam told me how they had to make head gaskets from cardboard or even paper plates becuase the real parts were impossible to get there.
Montgomery Ward
The photo of the child sitting on the MW riding mover. It says indistrial commercial. Is that valid claim for that product? It looks like a regular ole riding mower to me!
