Transportation Of Maytag Washer
boboh1
Jun 24, 2013
53
California
Is it OK to transport a vintage Maytag washer lying down on the backside or does it have to be transported in the upright position?
Back side isn't the best just because of the drain hose and water valve protrusions.  I prefer to move the on their side.  It does't really matter which side but I generally try to put the left side down just because the motor is on that side and it lowers the center of gravity just a bit.
Personally, I prefer transporting them on the back. The top cover has a rear overhang which offers some protection to the inlet valve and on later models the inlets are recessed anyway.
The drain hose is pain, I prefer to remove it for transport whenever possible. Also, laying on the rear hopefully limits any damage to back panel where it won't be seen once installed.
Just my 2 cents...
Whichever way you move it, be careful to secure the lid by taping it shut. I've heard horror stories about console damage to 'Tags when moving them!
(Bumping an old thread, as it seems like the best place for related questions. :-) )
For the center-dial Maytags, is there anything wrong with transporting a washer laying down on its FRONT? Obviously you would have to be extra careful during the loading, and it would have to be laying on something both flat and soft... But are there any structural or other reasons why it shouldn't be done?
Second question: Aside from opening up the panels to insert padding to stabilize the tub, are there any other "gotchas" for sideways transport? (Example: does the bleach dispenser get knocked around? Or are there any differences for suds-saver models?)
Thanks
Shipping
The machine should not be on its front as the tub support bracket will dig into the front panel.It should be on its side only.Maytag made a shipping ring that went in the tub opening and it is preferable to have that in place to prevent damage.
I moved a center dial MT on its side a few months ago and it wasn't harmed.
Yogi has mentioned in the past using a swimming pool noodle while moving a GE FF. Any reason they wouldn't work on a MT? Or just some old towels to lock the tub in place?
Moving A Maytag Washer
Is best with the washer on its side or back, if you don't have the shipping ring take the front panel off and pack heavy foam or padding around the top areas of the tub to keep it from moving around too much and denting the outer cabinet.
Do Not put anything inside the tub as this will not help at all and can actually increase the chance of damage by making the suspended tub assembly heaver.
shipping ring
I don't have a picture but it was a white plastic maybe 3 inches tall.There must be some around.I have a few but I am hoarding them,(among other things)use them all the time.At one time time I had an arsenal I used to save them from every delivery.
How about a bucket turned upside down and maybe some noodles or padding around that to keep the tub centered?
Just a thought.
