Hello,
Remember all the fun I had with my Monteray? Well its back again, but not as bad as before. Before I cleaned out the sump the motor used to throw the thermal switch on every drain. Now it only does it on the first two drains. If I run the cancel drain cycle first (with no water) I can greatly reduce the liklihood of the thermal throwing during the cycle but on occassion that still happens (but only enough after the first drain, after the drain purge, then the 3rd start of the drain motor it does it sometimes). So I guess I need a new motor huh? Could it be a relay? Never does it during wash ever, the thermal always blows in the first few seconds of the drain period (start winding staying on too long maybe?), when it happens i open the door wait 3 minutes or so then I hear a "click" which I assume is the thermal switch re-setting then I start it back up and everything is ok unless of course I don't run cancel drain first, then I have to repeat the process on the second drain (not the purge tho)
Sigh, such fun!
Any advice? I did smell a "hot" motor once but only once, so my bet is start winding staying on too long on drain when the motor reverses. What else could it be? Relay? Anyone ever rebuilt a motor on one of these early whirlpool KA's?
Thermally Protected in San Diego,
Steven
Sigh, such fun!
Steven
