Tub index
waterwitch
Apr 10, 2012
164
Pomona, Calif.
Question: What is the purpose for tubs to "index" during a wash cycle? Is this something that some manufactures strived for, or does this just happen when something is malfunctioning with the machine?
Is your washer tub indexing now Anthony??
Some machines do index while the machine is agitating. Not all makers use this function in their machines.
The purpose is to help the clothes move around in the tub. Some people like it, others don't.
The washer that I currently use is a Frgidaire TL that came with my apartment and it indexes. It's the first machine I've ever used that does that. I will say that it does like to tangle sheets into a mess when you go to take them out. I am surprised though that it does get the job done though.
People say that it deters rollover in the tub.
If you mention what kind of machine you have someone here will let you know whether your machine indexes or not.
1970's Westinghouse
Revvinkevin, I picked up a Westinghouse off of Craig's list, and from what I've seen on YouTube, it's from the 1970's, and it indexes. I couldn't pass it up, the price was right. It was FREE! Lol! Washdaddy, interesting, I have known for some to index, but wasn't sure why. I've always associated indexing tubs on cheaper models.
Fault or feature?
Doesn't that spiralator reveal a Weasyhouse? Weren't those better overall than the subsequent Whites?
Whether intended, or simply marketed, as a feature, indexing results from a unidirectional spin brake. That is, it only brakes in the (counter) direction of spin and is relatively free to move in the opposite direction. I don't think that necessarily connotes cheapness. A positive brake is one thing. A unidirectional brake actually requires another set of parts to make it unidirectional, though those parts may serve a dual purpose such as transmission decoupling.
Washer Tub Indexing
No Washer manufacturer ever set out to design a washer tub that indexed during agitation, As several mentioned it was just a CHEAPER way to build the machine. There is actually NO BRAKE at all, there is a torque spring that does hold the tub as the agitation reverses, but it is not a brake as such and the reason it is there is grip when the motor reverses to make the washer spin.
Only Franklin and Westinghouse ever designed and built washers that indexed, both of these brands were never considered good brands or great washers. Westinghouse TL washers from the 60s through the early 70s were terrible in regards to durability. WCI ended up with both these washer designs and did improve the durability quite a bit as the 80s and 90s moved on.
Indexing tub washers were a classic case of having a bad design and calling it a good thing, this is much the same as Spin Drain TL washers, they were basically built to spin drain because they were cheaper [ and sometimes more reliable ] to build, and then manufactures that built them tried to call it an advantage.
I loved the indexing Westinghouses!!! I, personally, do not think they were cheap machines. I believe they cleaned well, and depending on the usage, lasted long. As stated before, the indexing helped keep the clothes from becoming stagnant while the washing cycle progressed. My god mother had a Westinghouse with the blue agitator, and boy did it clean well. It lasted for a good 20 years. If I could get one now, then I would. Absolutely, my favorite washer of all time!
Indexing Washers
They index so that the dirt can escape from the clothes the minute agitation begins. I have a 1995 Frigidaire TL, it indexes and my sheets don't tangle up at all. Especially on spinning a heavy load of whites or colors, you can hear the agitator going "grunt grunt click click grunt grunt click" while coasting to a stop from spinning.
Most cases, the basket rotation is actively driven in one direction in repetitive short arc-distances, presumably by an effect related to the spin clutch and agitation mechanisms ... although it can typically be held stationary by hand.
Your F&P is different in that the basket truly is free-wheeling and the movement is sympathetic to the agitation and clothes motion.
Here's your answer:
It's called tri-action agitation. Call the company and see if I'm right.
Thanks,
Christopher
P.S.,
Here is a pic of one of the filter-flo washers here in Savannah at Bowen Refrigeration.
Modern SQ indexes
when new.
Here's my first vid uploaded right after I got the machine
Next, dozens of cycles later:
As you can see, the indexing has settled down quite a bit. Only on the heaviest cotton blanket loads does it index and even then, it is very slight.
Comments
I love that SQ indexing, even if other non-indexing washers get clothes as clean. I can't imagine this idea not helping out with certain stains, dirt and fabric types/combinations. Anyways, thanks for posting the video - I learned something new.
"No Washer manufacturer ever set out to design a washer tub that indexed during agitation"
So, your saying the Whirlpool VMW (DD replacement), whose tub indexes significantly due to the planetary gearing and no braking at all, is not designed to do that?
Clarification
I believe what he meant to say is that no manufacturer ever decided at the design phase to produce a machine that would positively index the tub. Of course, marketing research to determine if their was ever a manufacturer (WCI) proclaiming any benefit to a rotating wash action...
I always thought the indexing tub in the WCI machines helped take the strain of agitation off of the transmission. In an overloaded condition, I have seen those tubs really move...
Malcolm
The WCI
"stacker" that mom and dad had briefly in FL when they moved it indexed like a beast.
It also cleaned like an-about-to-be-fired maid. In other words, not well. They used it because, well it was there. But once it gave up the ghost, Dad got an Amanatag from Lowes. Along with an Amanatag gas dryer, that amazingly, still works!
"I believe what he meant to say is that no manufacturer ever decided at the design phase to produce a machine that would positively index the tub."
Well, the tub in a VMW machine moves back and forth significantly during the wash cycle and it is obviously designed to do this. Whether you can call this indexing or not is a matter of semantics I guess. If we refer to indexing to mean a tub moving when it shouldn't be then I guess the term doesn't apply to the VMW as it clearly is supposed to rotate back and forth during the agitation cycle.
Pic of Galaxy Box Fan
Just to let you know that I love using the older stuff. I had that fan and my dryer since 1982. Me and my appliances are 32, the more you take care of your stuff the longer it lasts. Just like these Unimacs at my job in the laundry. Here's Big Troy:
