Tub repair
skeggy56
Member
Jun 11, 2016
7
skegness, Lincolnshire, England
H Guy's and Gal's, It's me again with another question?. I have noticed a rust spot in the bottom of the tub on one of my twin tub's that has started to leak, What i want to know is what is the best way to repair this and other small rust spots, And what would be the best product to use to respray the insides of the tub?. The machine work's perfectly, It's just this hole problem now. Thank's Kev.
Re
If the metal has gone through, in an ideal world, the rust needs cutting back to sound metal and a plate welded in. Find metal of equavalent thickness to use. Once the welds are ground down, it can be protected with a 2-pack Epoxy Mastic paint from Rustbuster. With rust spots, just grind down the oxide to clean metal and paint on a converting solution, prior to applying your Epoxy Mastic coat. Don't bother using single pack Hammerite paint, or similar products. R
Welding is ideal but
Often not possible, for whatever reason.
Here's how we tackle the problem (nearly always one particular brand in the 'States, GE Filterflo tubs, but generally applicable):
1) Clean, clean, clean the entire tub inside and out. Not only to find damage, pinholes, etc., but because any repair is better when it's not contaminated by moisture, grease, rust, dirt, etc. Silicone is your enemy.
2) Remove rusted areas all the way back to healthy metal. You may well find a trace radiating out from the damaged area which, at first, looked healthy but would have quickly failed.
3) Composites hold better than single materials. If the areas to be repaired with JB-Weld (or equivalent) are large (bigger than 2cm diameter), make it a several step repair with some fibreglass  from the body shop anchored across the hole. Don't be afraid to think in three dimensions - you can built up the plug from the bottom, too.
4) Once everything is finished, one of the waterproofing PUR products (or equivalent) over the entire surface will go a long ways toward making things last.
5) Use it. Use it lots. I don't care what anybody says, appliances were made to be used. We have a saying in German: Wer rasted, der rosted. Goes for machines just as well as people.
tub repair
If you rest you rust, How true, Thank's Keven, I was thinking of using por 15 or something like it then triumphtoledo mentioned epoxy mastic so i have been looking at that aswell, Thank's for your reply. Kev. ps I'm still working on the 9404 tripping the rcd, Only now it isn't doing it!.Grr
Hey, Kevin,
I'd definitely do POR15 over any repair. A good repair and proper sealing and your good to go for pretty much forever.
As to the intermittent short. It will stay fixed until the day you decide to trust it. Then, it'll come back.
I guarantee it.
Keep us up to date - I got a lot of help with this sort of hole repair here about six years ago and the machine - used daily - has been happy ever since.
