Turquoise GE Wonder Kitchen with w/d! 2500 (Richmond, CA)
Wow - it looks like a late run '55 model.  The clock for the stove was changed for the '56 and onwards models and there is no 'automatic' burner unit, also seen on the post-55 models.  But $2500 for something that's gonna need a lot of work is a bit on the high side, methinks.
Looks good! It seems to be totally original - even the faucet, which has usually been replaced. The range shouldn't be much of a problem if it's not working properly, as it's basically a regular GE 24" range with the surface units in the SS countertop instead of the usual porcelain enamel top. The dishwasher and W-D units would likely be another story.
I do know that the custom fabrication charge to have a SS top made in that size, with sink and openings for the surface units, would well exceed the asking price for this unit.
Yes, but.....
one read the fine print.
".....and you should assume nothing works."
I maybe uninformed here, but given nothing works, well?
