Twinnie Troubles aka another addition
Lovlee
What a lovely machine to get Al, easy to work on as everyone else has said, yeah the hoses from the pump to the valve can be a real pain, if they are to stiff then the pump wont operate properly as it is mounred on a shaft and relies on a spring to hold the whole assembly with the drive tyre on drive pulley.
Best take the hoses off the pump end first.
with a bit of patience all the problems can be solved on these machines.
If you venture so far as to remove the control panel be careful not to kink the capillary tube that goes down to the tub from the temperature dial.
I have no parts left from mine just some nice memories
Good luck
Gary
well done
Al
yes looks in great condition visually. let me know if you need any parts, i have several of the gaskets that fit the ocv valve and some of the pump components which are the same as were fitted to the single tubs, but anyway see what you find when you set to work.
Nice to see the instruction card as well.
Mathew
Doing what HMs do best
When I first put hot water in both the spin can and the wash tub there was only the slightest leak from the wash tub pump - that actually seemed to stop after a while. So I put more water in the spin can and filled the tub up.
Switched on and everything seemed to run beautifully - smooth and quite quiet
And now the snags
The spinner pump is not working at all, not sure if it is seized or needs a new belt, at least it is a bit easier to get to than in the spinarinse.
I tried oiling the pump selector valve from the top but its still jammed. It was remarkably easy to remove which again seems to imply that it has been off before recently. The piston seems jammed but I will give it the vinegar rinse and see if that helps.
By this stage there has been hot water (slightly hotter than my hand could stand) for about 40 mins and having run it for about 8 minutes, the hose from the wash tub pump seemed quite warm so I gently tried to manoevre it down so i could gravity drain the tub and DISASTER - the hose broke in two places, the lower of which was right above the pump and it was water water everywhere - just as well it was outside. Thankfully I had unplugged it before starting. I suppose I had not left it soaking long enough.
So, now I need a new hose as well as all the rest :( The spin can hose seemed to be OK, but I will probably replace that too.
Hi Al,
Thanks for posting the pic's..It is the same machine that a lady opersite my parents had, It was immaculate as she rarely used and nearly always had a table cloth over it..I think it is long gone, but could still be there.
I will post some pics of the EE Liberator's over the weekend hopefully, the machines are still at a garage where i use to live so not easy to access.
Did you have any luck with the vactric ?
Cheers
Keith
Hoovermatic
Wow Al, thats one clean twinny for its age, never seen one so clean, ...those pipe always look fine until you start to move them...more likely original so best to replace them all, have used halfords pipes for replacements...again with the pumps either take it all apart and descale, you might want to take off the chrome cover during the cleanup...this area gets all the soapy residue and scum can build up...this is a pic of what you might have ..
The dryer looks great, thats the washer & dryer my grans brother had,it was in a small laundry area and placed on a built up concrete plinth...
