Two major projects tackled...WHEW!
westytoploader
Sep 4, 2004
4,485
Well...this weekend I looked at the back room and the garage and decided I needed to eliminate the clutter! So, you ask, what did a 1930's Dorby Whipper and a 1980 Shop-Vac 600C have to do with it? Because they were in pieces and I hadn't put them back together yet! Earlier this year, the Dorby's cord was getting a little ratty (and it was still being used by me) so I replaced it. The only problem was, I was missing a screw and could not put it back together right away. It sat in a box since March until yesterday, when I decided to go ahead and finish putting it together. My dad & I looked at it for a long time but couldn't figure out how to get the motor on without moving the motor bracket! It then dawned on me that there was a screw missing! Luckily I found what I needed and we put it together with no problems.
Later that night I got to work on the 1980 Shop-Vac 600. I ran the plastic parts through the dishwasher in May for a good cleaning, but unfortunately I had to break the strain relief to get the motor out of the housing. Fast-forward to September and I found some NOS Heyco 6P-4 strain reliefs (the type used on this model) online. After that it was a breeze.
While working on this machine I noticed that it and its newer counterpart, the 600C are both very well made. If you were to compare these machines with what Shop-Vac is making today, you would be VERY surprised. You just can't compare the quality of these old vacuums, which is why I am partial to metal-tank Shop-Vacs to begin with. The 600 has large handles on the lid unit that you can actually grab (later models just had a recessed lip, then no handles!), a metal tank, metal lid clips, and a sturdy toggle switch. As for performance, while both machines are 5-gallons and have only 1 peak HP, they have suction comparable to today's 16-gallon machines. I haven't had anything get stuck in the hose using either Shop-Vac, and that's happened with other 5 & 6-gallons I've used. So if you're an appliance collector and want a Shop-Vac, you're better off with a vintage model like these. Ignore the crap that's being made today; you generally have to buy a 16-gallon if you want ANY power at all; the 5-gallon machines are weaker than a Dustbuster!
Metal tank machines are still fairly easy to find, although the main problem is rust. The 600C's tank had a tiny rust hole in the bottom as well as some surface rust, so I had it professionally epoxied. The 600 was much better, so I just coated the bottom of the tank with Rust-Oleum. For a dry filter I recommend the Shop-Vac UltraWeb Cartridge, less expensive than a CleanStream but still works well ($15).
Here are the pictures of the un-finished and finished projects.
--Austin
Hey Austin, Your right about those new shop vacs being junk. I have had three the last few years(christmas presents)from Sears, and they all had to be worked on. Mainly the switches were very cheap and didnt fit into the housing well and the motor`s quit on two of them. Fortunatly the parts interchanged and I was able to keep one going. Now its gone and I need another so I`ll try to find an older one. I have an old electrolux to use for cleaning the car. Another thing I didnt like about the new ones is there so top heavy being made out of plastic. I used to keep a brick in the bottom to keep it from turning over when moving it around. See Ya, Don
switches on new Shop-Vacs.
Here at the place where I work they have 3 of those newer machines.On one of them-Used primarily to vacuum out the transmitters--The switch in it sticks-doesn't fail but sticks on.You have to take its soft plastic cap off and clean out the gunk and put the cap back-then its OK for awhile,then does it again.We used to have an older all metal 15Gal one-don't know where it went-was a GREAT machine.-Probably sommeone surplused it.At another radio station I worked at they had a really old Shop-Vac-a 5 gal size that had a fiber drum with metal top and bottom-had the inlet at the top of the tank.The motor was inside the drum.It worked like a champ!Wouldn't pick up liquids though because of the fiber drum.I do have a newer side inlet 15Gal machine that is Shop-Vac-But marked "Dayton"-Grainger's tradename.It has a SS tank.Its a good machine-but the sideinlet deflector clogs easily on pine needles.I have another 15Gal Tornado machine-plastic drum-side inlet-but a different deflector than the Shop-Vac-It eats up anything without clogging.Got it at a special price from Grainger-The motor needed a new bearing-replaced it-works excellent.Has an external filter bag-traps the fine dust.-the heavier stuff stays in the drum.Same with if you picked up liquid with it.
Shop-Vac in picture
VERY nice little machine-At a workplace I worked in in Downtawn Wash DC they used a machine like that as a dust collector on a band saw-even with all the fine dust-it could pick up very well.You could disconnect the hose from the saw and clean the small shop with it.The hose fit perfectly on a connector on the back of the bandsaw(Sears Craftsman)The saw was used for cutting everything.from wood to circuit board material.The top inlet gives a good Cyclonic action that prevents clogging-Why Shop-Vac changed it-Could it be so you would have to use the large paper bags they sell with the newer side inlet machines?
I thought of you a few weeks ago at an estate sale, Austin. Down in the basement was a very nice looking shop-vac similar to the ones you've pictured here but possibly a bit older. I've thought since that I should have grabbed it for the garage. I had a small Sears wet/dry vac which was borrowed and never returned. I'll have to keep my eyes open for some of these - you do make some good points about the construction and materials!
What have you whipped up in your Dorby? Those are very fun machines, I've not seen very many of them...
Vintage 1970's--1980's Shop-Vacs are great machines, and as Rex said, the top inlet really helps with power. Just be sure the metal tank is in good condition; you might want to coat it with Rust-Oleum just in case. The tank on my 600C had some bad surface rust so I had it epoxy-coated (which is a plus since I can use it with the Steam Team carpet-cleaning attachment).
The Dorby's a fun little mixer. When buttermilk or cream is whipped in it, it makes the fluffiest pancakes! The Dorby and Vidrio are basically the same, but with different housings. They both can handle light batters, even though they slow down considerably. A vintage ad for a Meljax similar to these (on this website linked here) showed a user taking it off the jar and using it as an ordinary hand mixer--the possiblities are endless! Whippers are relatively easy to find on eBay, and many are in good condition.
Here's a website specially devoted to glass-bottom whippers. He doesn't appear to have a late-model Vidrio yet like I do; mine is the first Vidrio to have an on/off switch--check out the "brake" on the early models!
--Austin
Glass bottom mixer
Looked at your link on the mixers-These are so similar to the Bamix that I have and use.The Bamix has detachable blades and beaters that could be something like the Dorsey and Vidrio mixers.In modern terms these machines could be called immersion blenders.In the websites "history" section they show an early Hamilton Beach mixer-this is so similar to the Drink mixers they still make today-The "Waffle" house restuarants use them to mix pancake and waffle batter-even scramble eggs.Other places use the HB machine to mix drinks and milkshakes.The glass mixers are still useful even today.And--a labware catalog I have (Fisher Science) shows similar machines used for lab mixers.They even have long shafts so they can be used in deep contain ers.I am trying to remember the company that makes very large immersion blenders-shafts up to a yard long for mixing large stockpots ful of soup in commercial kitchens.Chefs often call those "boat motors"
GLASS BOTTOM MIXER
HEY AUSTIN,
IS THERE ANY OTHER APPLIANCES YOU HAVE IN YOUR COLLECTION, THE NEXT GLASS BOTTOM MIXER I SEE IS YOURS, I WASN'T AWARE OF THERE VALUE, KEEP THOSE VAC'S HUMMING,
KIM
Very cool site, Austin. I will have to keep my eyes open for them at sales now. I found a stand drink mixer a while back at a garage sale, a Myers Bullet Mixer. Huge thing on a cast iron base with a chrome cup. It needs a new switch so I haven't tried it out, but would have never thought of using it for batters and eggs - and I've been to Waffle House and seen them do it! I haven't found much info on it, although they pop up on ebay now and then - for a hefty price too. My $20 investment seemed high at the time, but I guess it wasn't after all!
Check out the Myers Bullet auction and the seller's other items - some cool things up for auction.
Hi Kim,
I have 13 vacuums, 3 mixers, and 5 washers. That pretty much consists of what all I collect and look for at sales, used-appliance stores, or on eBay.
--Austin
