Hi Ricky / Mike..
I saw this machine on ebay and did think about it, but remembering back to when i had my last machine, i knew these were quite big, and space is a bit limited at the moment...
I luv the spin-rinse, via the central column, very much like the Easy twinnies, with regards to the coating in the spinner, it is the same as mine in my mk1..it was called a Rislan plastic coating.
The pulley probably needs tightening as Mike suggests. I am not sure if you got it with your machine, but there is a special tool/key that you get with the machine, one end of the tool is to undo the nut on the top of the pulley, which then lets you take off the pulsator, then the other end of the tool lets you release the big nut, which release's the filter (the plate with the holes in it next to the pulsator) this then allows you access to the heater, and the main washer drive...
I only kept a few things off my first machine, ie: badge, tool, washer tub, and water inlet arm..but they are great machine's..
Cheers
Keith
Ps. I will look the weekend at the tub and pulley i have in the garage.
