i have a fascia for a WM76P (TOL machine from the late 90s to early 00s) , with all the wiring looms
a motor is needed for it, but i have luckily been able to source one
the BOL machine is a WM71P ultima 1000 with a GEC motor, original suspension legs, a drain pump, inlet valves, and all of the wiring looms as well
the rebuilding of these beauties is probably going to end up being the largest project i have ever undertaken
donor machines will be needed (i already have plans set out for those), and hopefully i'll be able to give you all an update to this story every once in a while
here are the fascias of these beauties
