kennywhy
Occasionally I use my WO65-2 washer. From time to time I've noticed an intermittent chattering or slight squeal whenever the motor runs, assuming it to be the motor fan and choosing to ignore it. A change in this noise recently included a slight dimming of the lights on the same circuit as the washer, in sync with the chattering or clicking noise. Unwisely, on Sunday I chose to walk upstairs and away from the machine. A few minutes later I could hear the noise much more consistent and louder, and then sudden silence as I ran downstairs to find the machine stopped at the start of the rinse cycle and a smoke filled basement. The first and only time I chose to trust it running without "supervision"!
If it is the motor that has "burned out", why don't I at least get the timer to run? The machine is completely dead. The reset may or may not have popped out when the incident occurred (maybe just up slightly), It was hard to tell. The washer circuit didn’t click off. It’s got electricity.
Just wondering what you folks might recommend. Rewind and rebuild the motor, or look for a replacement motor? Or might there be something else going on I need to check.
I remember hearing some time back, that there may be some new replacement motors out there in Applianceville. It would be great to be able to purchase one. If so, and/or if anyone would like to sell a used motor that they are sure is working, I would be interested in buying it. Or am I better off rebuilding (by a pro motor rebuilder) what I’ve got?
If it’s only the motor that’s gone, I guess that’s not so bad. At least it’s rebuildable, replaceable and relatively easily to repair, as opposed to the Unimatic drive.
All thoughts and suggestions would be appreciated.
Thanks,
Ken
(313) 869-8058, or e-mail; [email protected].
Thanks,
Ken
