murando531
My father-in-law got a GoPro camera recently, and has let us borrow it to take to the beach this week. He also, with no prior encouragement from me, asked me if we could put it in the dishwasher to see what goes on. I said of course! We came home and after some packing and cleaning, I decided to pop it in after the load of dishes sitting had just finished washing.
To my painful surprise, the upper wash arm of the new Whirlpool PowerClean I just rebuilt seems terribly lethargic. There are two tiny little pin holes where a knife or some object knicked the ribs on the supply tube, but that shouldn't be enough to draw that much pressure and volume away from the arm. It's also making a good connection to the back as far as I can tell.
I'll try to upload a video when I get the chance this week. There is some water coming from the arm hub, which is normal from every video I've seen, but the rotation is terrible, and even gets "caught" or hesitates temporarily, though there isn't a thing in the way, and the flow output is stable. For every four or five rotations of the lower arm, the upper crawls around once. Speaking of the lower arm, it seems not to have a bit of trouble making a steady revolution every 1.5-2 seconds, and the pressure is intense enough to clatter Corelle bowls if they aren't spaced enough.
I even switched the lower ring bearings between each arm, but it made no difference whatsoever. The lower is still peppy and powerful, while the upper just crawls, squirting jets that are high enough to just hit the top of the tub but are in no way forceful. I guess any spray coming through from the lower arm was enough to compensate for the upper to this point, because I've still yet to pull a single dirty dish out, aside from the occasional spoon or knife that got stacked against another.
I'm completely at a loss, and it almost feels like a failure because I put so much time and work into trying to get it perfect. Does anyone have any ideas as to what could be going on?
