supermaticjames
Hi all,
I'm so excited I'm 99% finished with my latest restoration! The once worn looking 3314L is now gleaming and well. However I'm having trouble reading the wiring diagram kindly given to me and I cannot complete the restoration. Can anybody tell me what goes where or send me a picture of their 3314L wiring? Also my pulsator motor is quite seized up and it needs a hand to start and it doesnt really get to it's normal speed. It is definately not burnt out as there are no start windings in this design and there is no smoke.
Finally I found a solution to the lack of spin to pump hose and I found an old rubber drain hose from Gran's old spinner or twin tub and connected one end to the pump and put the other end on a plastic fitting and sealed all up with epoxy so it should do. Hopefully the only effect will be a slightly slower draining due to the approx. inch diameter hose and the pressure switch for auto rinse will be ok?
I'm hoping to do a wash and show you the end result on Tuesday.
Thank's in advance. James.
