sudsmaster
This house came with a workshop. In that workshop is a Binks air compressor. Model 331010, 30 gal tank, 3/4 hp motor, wired for 220 single phase.
It runs very well. However, it has a slow leak. I sealed off all the leaks I could find in the piping system (which runs around the shop/garage areas), but still the thing would lose about 10-20 lbs pressure a day with the motor off. Finally I closed the main valve between the compressor and the distribution plumbing (should have done that first, yes), and determined the leak in in the compressor itself.
The main suspect appears to be the "unloader valve", the purpose of which is to relieve pressure in the cylinder head after off pressure has been reached. This is so the compressor can start up again without fighting against retained pressure.
Naturally there's no manual for the thing and I can't find any online. I'm guessing the compressor is from the 70's. It says Binks all over it, but I gather that Quincy made it.
Most discussion of unloader valves shows them attached to the pressure switch. But this one doesn't have the unloader valve there. Instead it appears that the unloader valve is part of the head assembly. One video I found showed a later model Quincy with a similar setup, and said the leak in the case of that compressor was into the intake pipe (after the air filter). I'm planning on removing the air filter after pressure builds up (and compressor is unplugged, of course) to see if I can trace any leaks there. The other possibility is elsewhere in the unloader unit on top of the head, but I'm a bit leery of taking that apart without having a rebuild kit in hand (like diaphragms/orings/etc).
Anybody have any experience with older Binks/Quincy reciprocating air compressors?
