Automatic Dehumidification Window A/Cs
Whirlpool built window A/Cs for Sears from about 1960- the early 70s that had a separate humidistat control so the user could not only adjust the temperature but also precisely adjust the humidity desired.
They built many different models over this time period in capacities of around 11,000 and 18,000 cooling BTUs. the lower capacity models were built in both 120 volt and 240 volt the the 18s were always 240 volts.
We an 11,000 BTU 120 volt model at the museum, These were really neat machines, they have a 2nd condenser behind the evaporator so they can cool and dehumidify the room air but if the room is already cool enough but the humidity is still higher than desired a reversing valve similar to what a heat-pump uses energizes and flows into the 2nd condenser behind the evaporator and rewarms the air.
To my knowledge no other company ever did this, we had one of these units here in our house that I installed and my Uncle in Chevy Chase had two of them I helped install at their home that worked great, the early 70s one in a basement window is still in use and working.
Some central A/C units in the 50s-60s allowed you to select the humidity level in the house by running electric strip heating elements in the duct work while running the A/C compressor, this worked great but you can only imagine how expensive these systems were to run.
The best you can do today to better control humidity with either central or window A/C is to not oversize the cooling system, and to NEVER keep the inside fan running when the compressor shuts off. Using a lower fan speed can help a little bit as well.
John L.
