Amana update
Ok, just wanted to give an update on the Amana washer/dryer combo. They have been sitting idle in my garage for over a month now while I do some home renovations on my new fixer upper house and especially the bathroom where these two units will reside.
The washer needed some new belts so I went ahead and ordered . the two needed thanks to the helps of the folks here. Pretty easy job to loosen the tension adjustment mounts, slip the old cracked belts off and put the new ones on. I also lubricated the idler bearing on the main tub drive with a few drops of oil for good measure (hard to reach, but managed to deposit a few drops of oil onto it).
As for the dryer, I followed your guys advice and looked under the hood. I took off the front panel and then the duct that funneled air from the removable lint filter to the blower fan. Glad I did because as you can see it had quite a bit of built-up lint inside. Broke out the shop vac and thoroughly cleaned the entire insides best I could get the vacuum nozzle into the guts. The motor and pulley and belt seemed pretty inaccessible buried deep behind the drum. Kinda looked like I'd have to remove the entire sheet metal box enclosure to get to it.
Didn't want to deal with that hassle, so I looked for another way. I could see there was only one little bolt holding the exhaust vent onto the back so I took that off and voila - a nice hole in the back of the dryer that provided a "window' into the inner workings inside.
The belt looked fair to ok, not really sure because it was hard to see clearly from that angle. The idler seemed ok, and as per ya'lls advice, I lubricated it with a few drops of oil (again hard to get to completely, but did the best I could). I stuck the vacuum nozzle and hose deep inside and removed as much residual lint as possible. Overall looked pretty clean and orderly when I was done. The drum spun freely and quietly, everything looked great (the previous owner said it always worked fantastic). I turned it on after reassembly and it seemed to purr like a kitten. Heated right up too, in just 2-3 minutes it got hot inside. So the dryer seems to good to go.
After that I used my hand truck/dolly and wheeled both units into their permanent home. Hooked up hoses and drain line and now we're all set for our next load of laundry. The wife just did a load just 2 days ago at the laundry mat, so we'll have to wait a little while before the christening wash and dry cycle. Looking forward to it and possibly adding some sound insulation to the washer after getting an acoustic baseline in situ.
Thanks to all for the tremendous advice and assistance in figuring this set out. Presheate it dudes!
