Frigidaire Self-Cleaning Elecrtic Ranges
Were heavy well built ranges and one of the best SC ovens ever built. Frigidaire SC ovens had a 1/4" thick plate of aluminum directly behind the porcelain inner door liner to help transfer heat evenly for perfect cleaning and more even backing on these SC ranges. Frigidaire did add a window on some of their later SC ranges but doing so reduced the performance of the SC oven and hurt baking and increased energy use. As I mentioned in another post give me an oven any day WITHOUT a stupid window, they are a waste of energy and they are always dirty and they ruin the good simple looks of the range.
But Frigidaire s big down fall was the slow to heat and cool down Mono-tube surface elements. I have had several Frigidaire ranges in my adult life that I cooked on quite a bit and these elements are not nearly as good as the thin Chromeolox or GE elements, they never stay flat, you almost always end with significant red hot areas where the pan is not in contact with the element, I would NEVER install another Mono-tube element range as a daily driver.
