Vintage G.E. Air Conditioner
countryford
Nov 28, 2006
1,720
Austin, MN
A neighbor of mine, has had a vintage G.E. AC unit in a window(window was a metal casement window that was cut to fit the unit in), since he has lived in the house. Probably been there since the 60's. Anyways, he has promised to give it to me, when he replaced the window. Last year he replaced the windows in the front of the house. This year he started working on the back part of the house(which is where the unit is). Well, yesterday I was finally able to bring the unit home. It is dirty, and the cord on it is shot. He said he tried it, when he first moved in, and that it didn't work. With the cord thats on it, I'm not going to try. Here is a picture of it, with all its dirt.
that looks a lot like the beat up but still good running 1958 vintage,230v GE i use in the garage-nice running unit with it's low speed 4-pole compressor.Does pull it's share of 230v current though.Mine had the evap coil badly plugged with linty dirt-that is all that was wrong.
Model and serial number on the tag. Any idea when it was made?
I'm going to get this up and running, then install it in my "New" Laundry Room. Hopefully the Laundry room will be complete by this summer, and might have to have a Wash-In sometime this Fall.
looks slightly newer than the 1958 i have-i recon it may be from around 1962-65,mine has 4-blade metal evap fan instead of the clear plastic 6-blade though mine is a slightly larger unit and that might be part of the fan difference
Beautiful machine you've got there! There was one very similar to this in the sun room of a house my sister used to own. Wasn't the quietest AC ever made but it still worked and seemed antique back then! I'm not sure what kind of fan motor/bearings that thing had but the fan would continue spinning for what seemed like forever when switched off! Does yours have that little condenser fan visible from the outside? Hope you get it up and running without too much trouble. Keep us posted.
Ovrphil . . .
Good link to the Life magazine with the GE ad, looks to be a great issue with Zsa Zsa Gabor on the cover and an ad for Swift deli meats on the page after the GE ad explaining how to give a "Gay N' Easy Party" . . .
How to Give a Gay and Easy party
LOL! I didn't see that - it'd have to be rewritten of course, for what you had in mind. :-)
And Zza-Zza - is she 94 now? Glad you enjoyed the link.
Wow, that's actually older than my vintage Frigidaire's! My neighbors unit, which is for sale, has a similar round diffuser. I should have them save it for someone on here if they replace it. Another neighbor actually has a casement unit installed on a steel fire door!
Well I took the unit apart. Replaced the cord and a switch that was bad on it. Also cleaned it up real well. Anyways, plugged it in, and the fan blows quietly. It appears the compressor kicks on, but is not blowing out cold. My question is, if an a/c unit sits for 20+ years will it need to be recharged? I talked to an a/c service tech and he said most a/c people won't deal with the wall a/c units. But thats mainly the newer ones. Should I try and locate an a/c guy here that will look at it? It uses R22 in it, is that the same as refrigerators? and if it is, will a refrigerator repair place take a look at it? Thank you.
I made this suggestion so another member
Some high school vocational programs have HVAC and Refrigeration courses. I know one in the Charleston, SC area that loves to fix old refrigerators and equipment. Tbey use them as a teaching tool See if the local high school has a program and talk to the teacher to see if he has a class that can help you out.
Joe
jamman_98
I have this unit
Hello I have this unit in my home and it still works but is leaking water down the wall tried putting shims to tilt 5 degrees for better drainage no go... anyway do you happen to know the dimensions so I can replace it with a new one... If anyone wants the one I have I would gladly sell it .... it works great other wise..
caidensmom: you say you have one that you are wanting to get rid of? I would be intrested in it. Do you have any pics? Where is it located? and How much are you wanting for it? The only thing wrong with it, is that it leaks? Thank you.
Air Condition Grille
Hello, I'm looking for a 50's or 60's grille in good shape. Any info about finding one would be appreciated. Lookin for one like in picture. Thanks
HEY BRENT,
Glad to see you like the "circle of air" grille design, too.
They really work well.
I suggest you can call the following guy, in Chicago. He
deals with A/C's and Grilles from all eras.
ED / Nu-Dell Appliance Inc.
773-771-2140
Good luck.
Louis
