tina
pifco lights
Hi Grant, the push in lamps can be interchangeable. A lot of the push in bases are not glued. If you pull down the metal wires you can slide the plastic base off and you can then replace the glass lamp with one of the same voltage etc. I hate to see old sets being thrown away so found a way around it
