One quick post from a long-standing lurker...
A bit of feedback about the VZug Adora SLQ, which I've owned since May 2009.
Pros:
- the Steam function (for de-wrinkling shirts, sheets etc) actually works!
- flexibility: you can go for a 95° wash plus easy care function, add the steam anti-creasefunction, a pre-wash, etc.... no problem.
- the Vibration Absorbing system seems to work very well indeed. Always perfectly spun laundry.
- excellent wash and spin results
- the Wetclean programme is perfect for dry-clean only garments
- extremely quiet
Cons (?)
- not as solidly built as a Miele (just my impression)
- not sure about the Fuzzy Logic function. According to the catalogue, when 3.5 kg of laundry is washed, consumption is 0.7 kwh and 33 liters/ water. My impression is that comparably more water is used than in my Miele W6749. Is this good or bad??
- not sure about the new 'Textile' programmes. In my Miele, I can see changes in tumbling speed/rhythms, water levels etc when I select some (ok, not all, but some...) of the new designer programmes (e.g. Sportswear). The Adora only seems to add an extra rinse or reduce the spin speed... Again, just my impression
- the night function --> savings in energy by reducing wash temperature and lenghtening the programme. Does it make sense? Do you really get the same results with lower temperatures and a longer wash???
It'd be great to hear from somebody else who's got the Adora. Any Swiss AW-users??
Change of subject: any update on the 'Reason' washing machine? Did anyone actually get hold of the ones that went up for auction in March?
Pros:
- extremely quiet
Cons (?)
