The Good:
Water Valve Works
Goes through entire cycle
The Bad:
When I had it on its side to put more glop on the tub hose, the end bell for the motor leaked onto the pump wheel so when the pump kicked in, it spun in place. Cleaning the grease off the wheel solved that problem. (Motor leaking, not good)
The tub hose still leaks, I found the exact spot and will put more glop on..its the hose part away from the tub..the glop is like rubber cement, that's why it looks droopy
There is a mystery leak coming from where the pulley slides up and down. (the first pic) It looks like water with some grease in it. Ill have to go in there and look around..could be the nearby shock absorber.. It does not look like the tub leaks from the outside, as its in nice shape
I have a new video of the mystery leak and potato pulley action..[this post was last edited: 2/28/2016-15:35]
Water Valve Works
The Bad:
