Walker built-in dishwasher with sink in Mich
The KD-5 uses about 2.3 gallons per fill. Old impeller machines did use only 1 to 1.5 gallons per fill. The only spray arm DWs that used 3 gallons per fill were the older Maytags in the 70s and some Westinghouse machines. Frigidaires from 1965 to 1980 may have also.
Kevin, From the owner's manual for a power shower Mobile Maid, each fill is 14.5 PINTS. 2 pints per quart and 4 quarts per gallon so 7 quarts + 1 cup means not quite 2 gallons per fill.
From the owner's manual for one of the GE automatic top loading builtin dishwashers often paired with a sink, each fill was a gallon.
From the specs of Robert's 1950 WH rollout with the aluminum impeller, each fill used 7 quarts of water.
From the specs for his APEX Dish-A-Matic,another impeller machine, each fill is 1.5 gallons.
From the owner's manual for the 1956 Hotpoint impeller dishwasher, each fill is 6 quarts of water.
From the owner's manual for the Westinghouse SUC24 series from the early 60s, courtesy of Steve D as in Dishwasher, each fill used 2 gallons of water. These were the ones with the tall Bakelite impeller.
I was just at the Plumbing museum outside of Boston, MA...and I believe they featured a Walker very similar to this (it did have the racks)...
