Keven,
I can see the problem... especially with the impetus on the part of the manufacturers to offer additional cycles, which naturally might make the dial more crowded.
The US made Speed Queen front loader, the one with the internal heater, uses Candy (formerly Hoover)/Siemens system of stopping agitation while the heater is working.
US made electronic washer control panels seem to be getting better. Since both the main and motor controllers were replaced in my Neptune in 2003, the machine has been running more or less flawlessly. I was told that in both cases the replacements were upgraded versions. I suspect the motor failure damaged not only the controller, but also the main board. The machine still worked after the motor/controller were replaced, but would halt randomly in the middle of cycles with an error message. A new main controller fixed that issue, plus it had updated firmware that addressed some anomalies in the Favorites program editing.
One of these days I'm going to have to do a test run on the '71 piano key Lady Kenmore. Various keys can modify the timer function, such as extending the wash or adding a second rinse. The timer dial itself has little indication of what is happening, it's dependent upon the key selections.
