no index to 60 minutes
Rich,
You are right, of course - the manufacturers can speed up or slow down the steps with gearing.
There is a problem with fixed step length gearing. Since the dial has to cover all the possible programs within one 360° turn, one doesn't want the duration of each step to be too short. Imagine a 15 second step...well, a spin of three minutes would take 180/15= 12 steps...obviously that would cut down on the space for other programs very fast. On the other hand, too long of a step also has its consequences. Somewhere around 180 seconds/step maximum the point is reached at which one can do a normal, permanent press and delicate program. Up that a bit, maybe a short "soak".
But by the time the 2nd rinses and pre-washes and and and are there...well, you can see why some makers just said, fine - if you want a longer wash or second rinse, just turn the dial back. Some even advertised this as a "special" feature - total control in your hands.
(I guess Microsoft copies everything, "it's not a bug, it's a feature" has to have come from those ads).
Electrolux in early Frigimore FLs just let the US timers run faster than in Europe - the 50/60Hz thing. That one got fixed pretty early on tho' - but was still true in 1997.
Some US makers did introduce variable pitch to their steps, this made it possible to add more cycles or adjust individual step lengths to better match needs. Those machines were expensive and complex relative to the standard US timers.
European timers used different systems to solve the problem. The simplest (cheap Candys in the 1960s and cheap Siemens) simply turned the timer motor (and agitation) off until a certain temperature (about 40°C)in the tub had been reached.
Candy even saved an adjustable thermostat by simply having an enormously long time span for each step. If you set the machine to do a 40° wash, the moment the temperature of 40° was reached, the time motor started up and the clothes had the shortest agitation period. If you chose 90°, the machine simply ran through several more steps. The heat rise from a given point was more or less linear and the machine could simply "anticipate" any given temperature based on the time lapsed.
Sorry that is not clearer.
The Siemens system did have an adustable thermostat, the motor started when the temperature was reached which you wanted and each load of clothes got the same length of agitation - you could chose more or less.
Bauknecht (before Whirlpool messed that up, too) used incredibly complex timers. Some had two motors, others had solenoids which swapped the timer step advance gear in and out permitting the machine to agitate back and forth during heating. AEG, Electrolux, etc. used various similar solutions.
Miele for years and years used a system which made "rapid stepping" through the cycle possible. Primitive solution to out of balance loads, but it worked.
Of course, with the introduction of reliable electronic timers, all these mechanical solutions are dying out.
Given the lousy reliability of the electronics in US washers and the very high reliability of mechanical US timers (only thing the Americans do better than the Europeans is mechanical timers), it is a form of built-in obsolescence. Oh, the electronic timers can be built to be reliable...Miele solved the problem in the 1980's as did others...
