ryner1988
Hi all,
When my DD washer was delivered a couple months ago, I think the drain hose they supplied with the machine was too long for my setup. I noticed over the past week or so that when the washer drained, it didn't sound like it was draining very fast or well. As in, the water would empty out of the machine just fine, but it would take a while and I could not hear a good solid flow of waste water exiting the pipe, as one is supposed to. I checked it earlier this evening when running a load of towels, and I think I found the reason why.
It appears that a heck of a lot of drain hose was shoved into the standpipe, probably about 20 inches or more. I pulled the hose out of the pipe so that the curve of the hose is slightly above the machine, and it now only enters the pipe 6 inches or so. This seemed to fix the issue -- the washer now drains quickly and effectively. I can now hear the water running unimpeded through the pipe, so it seems the problem was nothing more than the hose being shoved too far into the standpipe. I have secured it in place with duct tape for now, but would like a more permanent solution to keep it in place. Or maybe I should cut the extra length off?
Any ideas?
Ryne
Any ideas?
Ryne
