washer will only fill for 15 seconds
hobart
Aug 23, 2009
Frigidaire LTF2940eso front loader, made 2 loud thuds and stopped working when final spin started.Now when you turn it on it will lock door and attempt to fill for a few seconds and then does nothing and wont drain.The digital display does not show any error. Any ideas what could be wrong with it??? Checked pump it spins freely and so does drum, no broken belt any help would be appreciated. Thank you, Hobart
Right Place!
Well, Mr. Hobart, I do think this will be the right place to get an answer on your problem Frigidaire washer. Many members are familiar with these front loaders so just keep checking back and see what comes your way!
Try unplugging for a few minutes and plugging back in.....that's always the first so called rule to check...sometimes this resets everything....had to leave my calypso unplugged for a few days, YES DAYS, to clear out a static charge that builds up....
also the service man hooked up a ground wire from machine to the cold water pipe and recommended I keep unplugged when not in use, never a problem since...who knew?
