I have a few bin bags of different door seals for UK front loaders IE Hoover hotpoint indesit and candy to name a few if of any use to you please get in touch all I ask for is the cost of posting
my papa wondered if youve got 2 servis doorseals for a 308S that'd be great,also if youve got one to fit a bendix 7128 itd be great, and a hotpoint 9534 seal that way ill have a spare for all 3
phil
I know some Servis door seals were the same as Hoover back in the late 70's through to the 80's sadly the stickers have come off the ones that resemble Hoover/Servis so if you want to take your seal off lay it flat and measure the distance across the middle of the inside that seals around the tub and the front that seals the door if you can send me a picture of the seal you need and I will try again for you am sure there is one that may fit
I will have another look in the meantime if you run a maintenance cycle with a bottle of THIN bleach from lidl for about £1 when the machine has stopped filling put the container of bleach in through the soap drawer and let it run a 90 wash that will kill off any more bacteria and fade what is leaving its mould behind. you should then be ok to use the machine as I am assuming its not leaking ?
