Hi All,
I just moved and could use your expertise. My new home has the washer drier hookups (prior owner left his drier) in the basement, but unfortunately the only access to the basement is through a narrow stairway with a bump, which at its narrowest point is only 23 inches wide. I have done a fair amount of research (mainly through reading prior threads on the site) and the best solution I have come up with so far is the SpeedQueen 3.3cu.ft. top loading washing machine. My concern is that even that might not fit disassembled. Does anyone know the dimensions of the speed queen disassembled? Also, does anyone know of a larger unit that can be disassembled and reassembled to fit down the narrow stairwell.
Thank you all in advance!
Justin
Justin
