Newer top loading washers with wash plates
Clean very well and generally clean much better than old deep fill agitator machines, Consumers simply will not put in enough detergent in a top load washer with an agitator to make them clean as well as and impeller machine or front load washer.
And if you do use enough detergent to get good cleaning and a top loader, you have to double rinse because top loaders that fill all the way up generally don’t rinse that well because they’re just immersing the clothing and a bunch of water.
If you use two deep rinses, the performance gets pretty good however, you’ve used 2 cups of detergent to get them washed and about 75 gallons of water for the entire cycle not something the world can sustain.
John
John
