Ah, yes
This machine is a different beast than the Steam Machine. The steamers were great if you ran the steam generator all the time, but if you didn't, then at least on the non-rapid advance machine, you experienced a small delay in washing while the timer trudged through the part where the steam delay would otherwise take place. This cycle of "fill, wash, sit and cool, resume" severely hampered the wash performance.
Having a machine like this minus the steam generator might make up for that.
This machine had some pluses, like a cool upper rack where you could remove all the dividers and have a big, flat basket if you wanted, which was great for prep bowls, because you sure as hell were not going to get bowls in the ultra-rigid, curlicue-tined bottom rack, which commanded structured loading. In desperation, Ralph and I used to perch things on other things, just to be able to cheat and get them into the bottom rack at all. (Oftentimes, stuff stacked over the silverware basket.)
Another plus was the thin, low-profile top wash arm, which reached all parts of the top rack well.
We did have to replace the hinges on ours when we started the restoration, but I believe John pointed out back then that custom cabinet panels with their heft tended to cause bent hinges over time anyway, and ours came with one of those ridiculously heavy cabinetry inserts.
These are fun machines if you find one in good condition, and they're handsome too. The Steam Machine we had performed slightly more poorly on the regular cycle than a D&M; if we ran the full steam cycle, considerably better, especially with baked-on stuff.
