Three times?? Yeah, Sure!
Look at the rinse and hold button..it is all worn out! That machine has seen some washes! And the wash arm support looks used as well. Be careful of rusting in the sump where the element ends come thru the tank..very weak link there. Saw many with rusting in that area. Also, the little tube for the air pressure switch that is part of the machine on the right side of the sump tended to get plugged up so you should check that out too. If you break the air switch hose, replace it with the same length to maintain proper overfill protection.
You will get alot of stuff in it and of course, the top is for the big stuff. 16,17 and 18 series racks will fit down there too and will give you some versatility! Check it out.
You will love the rapid advance timer.. really cool mechanism.
Utitlity and utensil has only a five minute dry so nothing cooks back on! And wait till you get a load of the 180 Degree Sani Rinse!
Good Luck.
I should have nevr given my friend the one like that I found that was NEVER used and was thrown out to the curb! Still had all the stickers inside..but that was nearly 20 years ago and I am sure he never even hooked it up!
Later Big Ed!
