Well, now it has turned into a restoration project....
davy1063
Sep 26, 2002
352
Pennsylvania
Now that the motor problem has been solved, and the machine is in a state of disassembly.....I decided to do a full bore restore.
While the tub was out I figured I'd give it a bit of a cleanup:
well...look what I found....
A couple of pinholes right above the mechanism. After a good working over with a wire brush, I filled in the areas
The other areas are good and firm with no penetration.
Now the next step is AW.O's saving grace. Where would our wonderful appliances be without the ever-popular, immortalized in song and stage, the highly coveted.....
Way to go Davey
So cool you are going to restore the machine.......Keep us updated with the progress!
Mark
ahh what fun. your on the right track .. mine had all that rust too but with a good clean and seal its ok.. great job keep it goin
Thank You SaltySam!!!!!
Mark gratiously sent me a handfull of tub screws. I was able to drill out the remains of the broken two and retap and replace them.
I owe ya Mark.
POR-15
I bought mine at an automotive body shop supply store.
Two things they stress:
1) wear gloves, because if you get it on yourself, ONLY TIME WILL TAKE IT OFF
2) see thing #1
Davy
