Here's a nice Westinghouse refrigerator that I found locally. The guy wanted an arm, a leg, and half a torso for it. But, when I went to look at it, it had oil in the cabinet, and was not working. I looked it over and the condition was so good that I decided to haggle with him. Got him talked down to a reasonable figure for a non running but nice piece such as this. (don't want to talk dollar amounts on open forum though)
The only real uglies were worn door hinges, and a door latch that wouldn't release every time.
Having fought the door hinge battle before on a friend's CK monitor top, I knew that simple machining flat and bushing install would get these working like new, so that I did.
For the door latch, it took soldering in a sleeve made of automotive brake line tubing. Then that was filed down to width and everything was right with the door!
Try as I might, I couldn't find the refrigerant leak. It held vacuum overnight, and I could not find any leak with soap bubbles nor with an electronic refrigerant leak detector. Maybe this is one of those "50 year leaks" that nobody can find!
The unit gave me a challenge to get refrigerant in it. Seems they had a very poor design for the charging port. It would not accept flow into the system because of a loose ball below the service port screw. This ball would drop down and act like a check valve. I had to fabricate a new service port screw which holds the ball captive. This allows both evacuating and charging. After that, the gas went in easily and the unit works great.
The condenser fan motor was running slowly and was gummy feeling to turn. It had to come apart completely and have the oil wicks cleaned and re-oiled. I used the blue can 3-in-1 electric motor oil. This fan motor is interesting, and irreplaceable. It is a 2-phase motor. The design Westinghouse used is quite fascinating. The compressor motor is used as a rotary phase converter. After the compressor is running, the start winding of the compressor motor generates a second phase, 90 degrees shifted to the incoming power angle. The fan motor uses this to provide starting and high power in a compact size. I re-varnished the stator winding as well as replaced the motor's lead wires.
Every wire in the unit has been replaced. They were all hideously deterio-rotted and unsafe at any voltage.
I love the art deco styling. The cabinet is porcelain enamel with only a few tiny chips. It has a tray table that folds up in the door, and a rotating shelf. There are 3 drawers in it as well. Very deluxe indeed!
There are more than one person wanting this one, once it runs a few weeks and proves it's going to live. The compressor doesn't sound "bad" but it is louder than I expected. It is cooling well and not showing excessive run times, though.
Repair videos. Note that each video ends with a link to the next.
Sincerely,
David
Sincerely,
David
