Early 70s WH DW
This was the last totally WH designed and built DW before WH went to WCI.
This is easily the worst DW built in this time period in many ways and did not work nearly as well as the WH DWs that came just before that had a filter.
This DW is such a joke that I have actually kept one in the museum line-up, it is a really interesting attempt to built a cost competitive DW when WH was on the brink of closing. Every possible corner was cut designing and building this DW, No wheels on the racks, no detergent dispenser, no filter, 5 rinses to try to clean up the mess, very poor durability pump assembly where the 1/2 carbon steel motor shaft would literally rust to the point of breaking off, The plastic fan would disintegrate and blow bits of melted plastic out on the floor, the drain solenoids would burn-up from having to be energized the entire wash and rinse cycles.
If this were a car it would be an eastern block Trabant, LOL
The only good thing about it was the timer could be turned in both directions and the tank and door liner were porcelain coated.
Hopefully this was an unused machine and may be in excellent condition, I will be interested in hearing your comments on it Barry,
It should be fun I have never known anyone that had one that was very pleased with it and they had such a short life you never see them any longer.
John L.
