Westinghouse Electric Range D64-47
Thanks wiskybill, I saw that one but they said they took it out of what sounded like a trailer, so one not sure it would be the same and two, not sure why they took it out so wasn't sure if it was worth the risk?
Thanks RP for the info, makes me feel more confident about diving into it!
Nice kitchen!
Glad I was able to help you with the wiring for it.
I like the way you mounted the sink. It reminds me of the one in my dad's Uncle Harry and Aunt Mabel's house. It was a cast iron sink with legs, and original to the home's 1916 construction.
Thanks Jim,
I always type "vintage" into my appliance search but clearly that's not the best strategy.  I've provided a link to the CL listing.  I think this stove's burners would be an exact fit for BC's stove.
https://sfbay.craigslist.org/eby/app/d/berkeley-westinghouse-stove/7371050790.html
Two 6" Elements For A vintage WH Range
You need the 2 coil type for this older range, the element would have 3 power connections, there may also be a ground wire [ the black wire is not a ground ]
The elements in reply #30 could work but you would need the trim rings and drip bowls that go with these newer elements and you would take to use the newer switches included with these elements so it could be more work to install but you would have infinite heat controls on these two elements instead of just 5 heat settings. The elements in the add are basically new but you would need to be sure they are 240 volts not 208 or 120 volts.
John L.
Thanks for the info!
I ended up just buying the burners mentioned in reply #30 as well as another 6" burner. Hopefully I can get at least one burner working :)
Cheers!
